Einleitung
Cleaning your optical drive is standard maintenance especially if your movies wont play. Here is how you get to it and clean it properly.
Was du brauchst
Remove the four 5mm Phillips #1 screws that connect the black outer shell to the silver back of the device.
Lift the black cover to a 45 degree angle from the rear of the device and pull the cover away entirely.
To access the optical lens, pull back the optical drive as shown in the pictures located on the two metal rails.
In diesem Schritt verwendetes Werkzeug:Microfiber Cleaning Cloths$3.99
3 weitere Nutzer:innen haben diese Anleitung absolviert.
