Einleitung
The motherboard is found below the WiFi antenna inside the device. This guide will take you through the steps of removing the motherboard for replacement.
Was du brauchst
Remove the four 5mm Phillips #1 screws that connect the black outer shell to the silver back of the device.
Lift the black cover to a 45 degree angle from the rear of the device and pull the cover away entirely.
Use the metal spudger to remove the white clip from the antenna by prying the clip away from the antenna.
Lift up and out to remove the large white plastic wiring strip. Lift lightly on the back clip holding it to loosen.
Remove the power connection to the motherboard small white clip with 4 white wires coming out.
Pull the larger white 9 pin power cord that connects the power board to the motherboard.
Pull the second white 1cm wide tab between the motherboard and power supply board.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
