Zum Hauptinhalt wechseln
Dynex DX-WBRDVD1 Optical Drive Replacement
Was du brauchst
  1. Dynex DX-WBRDVD1 Optical Drive Replacement, Top Cover: Schritt 1, Bild 1 von 2 Dynex DX-WBRDVD1 Optical Drive Replacement, Top Cover: Schritt 1, Bild 2 von 2
    • Remove the four 5mm Phillips #1 screws that connect the black outer shell to the silver back of the device.
  2. Dynex DX-WBRDVD1 Optical Drive Replacement: Schritt 2, Bild 1 von 1
    • Remove the two 5mm screws on the left and right side panels.
    • There is one screw on each side that secures the cover to the body of the device.
  3. Dynex DX-WBRDVD1 Optical Drive Replacement: Schritt 3, Bild 1 von 1
    • Lift the black cover to a 45 degree angle from the rear of the device and pull the cover away entirely.
    • Check that the power cord is not preventing the device from opening or closing.
  4. Dynex DX-WBRDVD1 Optical Drive Replacement, Optical Drive: Schritt 4, Bild 1 von 2 Dynex DX-WBRDVD1 Optical Drive Replacement, Optical Drive: Schritt 4, Bild 2 von 2
    • Use a Phillips #1 screwdriver to remove the two screws that secure the Optical Drive.
  5. Dynex DX-WBRDVD1 Optical Drive Replacement: Schritt 5, Bild 1 von 2 Dynex DX-WBRDVD1 Optical Drive Replacement: Schritt 5, Bild 2 von 2
    • Detach the tape wires from the motherboard and power board.
  6. Dynex DX-WBRDVD1 Optical Drive Replacement: Schritt 6, Bild 1 von 2 Dynex DX-WBRDVD1 Optical Drive Replacement: Schritt 6, Bild 2 von 2
    • Lift the disc drive up to a 45 degree angle and pull back out of the device shell
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 6
Insgesamt: 384
