Einleitung
This is the guide to crack into your device, almost every repair guide will need this completed first before being able to tear into the hardware below.
Was du brauchst
Remove the four 5mm Phillips #1 screws that connect the black outer shell to the silver back of the device.
Lift the black cover to a 45 degree angle from the rear of the device and pull the cover away entirely.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
