Zum Hauptinhalt wechseln
Dynex DX-WBRDVD1 Top Cover Replacement
Was du brauchst
  1. Dynex DX-WBRDVD1 Top Cover Replacement, Top Cover: Schritt 1, Bild 1 von 2 Dynex DX-WBRDVD1 Top Cover Replacement, Top Cover: Schritt 1, Bild 2 von 2
    • Remove the four 5mm Phillips #1 screws that connect the black outer shell to the silver back of the device.
  2. Dynex DX-WBRDVD1 Top Cover Replacement: Schritt 2, Bild 1 von 1
    • Remove the two 5mm screws on the left and right side panels.
    • There is one screw on each side that secures the cover to the body of the device.
  3. Dynex DX-WBRDVD1 Top Cover Replacement: Schritt 3, Bild 1 von 1
    • Lift the black cover to a 45 degree angle from the rear of the device and pull the cover away entirely.
    • Check that the power cord is not preventing the device from opening or closing.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 136
