Einleitung
Dies ist eine Anleitung zum Entfernen der Bürstenleiste zum Ersetzen oder Reinigen.
Was du brauchst
Hebe die Bürstenleiste vom Gehäuse weg, während du sie gleichzeitig zur Seite ziehst.
Befolge diese Anweisungen in umgekehrter Reihenfolge, um dein Gerät wieder zusammenzubauen.
21 weitere Nutzer:innen haben diese Anleitung absolviert.
100%
Hier starten ›
15 Kommentare
I'm like to know if this works for the Dyson ball animal2 as well
It does work
ade 23 -
We used this guide to clean the brushbar assembly of the DC41 animal too. Thank you SO MUCH for writing it!!! We’d never have tried pulling the bar off sideways.
Thanks to MaireadNye for the easy to follow guide. I used this to remove and clean the brush bar and its housing on a Dyson Animal 2 upright vacuum. The four screws securing the brush bar were not T10 Torx, but rather Phillips head, so no big deal. What took the longest amount of time was searching for my Torx tools before I began, which is unlike me. I usually grab tools as I go, but since only one was required, I decided to (unnecessarily) have it ready to go. I used vinegar first to get out a soy sauce type smell, but dish soap was what worked. Thanks again!
(And thanks to Dyson for making stuff like this user-friendly!)
what is the part and part number of the wheel in between the brush bar?
