Zum Hauptinhalt wechseln
Dyson Cinetic Big Ball Animal Upright Brushbar Power Button Replacement
Was du brauchst
  1. Dyson Cinetic Big Ball Animal Upright Brushbar Power Button Replacement, Brushbar Power Button: Schritt 1, Bild 1 von 1
    • Gently pull up on red handle to separate the hose from the external hose of the Dyson.
  2. Dyson Cinetic Big Ball Animal Upright Brushbar Power Button Replacement: Schritt 2, Bild 1 von 2 Dyson Cinetic Big Ball Animal Upright Brushbar Power Button Replacement: Schritt 2, Bild 2 von 2
    • Locate the 18mm four screws on the Dyson above the sticker.
  3. Dyson Cinetic Big Ball Animal Upright Brushbar Power Button Replacement: Schritt 3, Bild 1 von 3 Dyson Cinetic Big Ball Animal Upright Brushbar Power Button Replacement: Schritt 3, Bild 2 von 3 Dyson Cinetic Big Ball Animal Upright Brushbar Power Button Replacement: Schritt 3, Bild 3 von 3
    • Unscrew the four 18mm screws.
  4. Dyson Cinetic Big Ball Animal Upright Brushbar Power Button Replacement: Schritt 4, Bild 1 von 2 Dyson Cinetic Big Ball Animal Upright Brushbar Power Button Replacement: Schritt 4, Bild 2 von 2
    • Locate and push the grey button (where the index finger is pointing) while simultaneously pulling up on the handle.
  5. Dyson Cinetic Big Ball Animal Upright Brushbar Power Button Replacement: Schritt 5, Bild 1 von 2 Dyson Cinetic Big Ball Animal Upright Brushbar Power Button Replacement: Schritt 5, Bild 2 von 2
    • Pull on the plastic case below the power and brush bar buttons to separate it from the Dyson.
  6. Dyson Cinetic Big Ball Animal Upright Brushbar Power Button Replacement: Schritt 6, Bild 1 von 2 Dyson Cinetic Big Ball Animal Upright Brushbar Power Button Replacement: Schritt 6, Bild 2 von 2
    • Slide the buttons out from the case and replace.
Abschluss
Karla Sunjara
891 Reputation
5 Anleitungen geschrieben
Cal Poly, Team S13-G1, Banghart Winter 2017 Mitglied von Cal Poly, Team S13-G1, Banghart Winter 2017
CPSU-BANGHART-W17S13G1
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 24
Insgesamt: 2,591
