Einleitung
The Dyson brushbar is located on the underside of the base of the vacuum.
Was du brauchst
Lay the brushbar flat as if it was vacuuming.
Locate the two red tabs on either side of the brushbar frame.
Lift up the red tabs and the brushbar frame will come off.
Place the Dyson brushbar on its back.
Locate the four 15mm screws in each corner of the black plastic.
Unscrew the 15mm screws in all four corners of the brushbar.
Remove the brushbar and replace it with a new brushbar.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
3 Kommentare
If you look toward the center part on each side of the belt container you'll see 2 little clear tabs sticking out on each of the inner parts of the purple brush. Use a flat head screw driver and gently push each of those tabs in (obviously one side of roller then the other side) as you pull outward on the outer side of the roller (it's a 2 piece roller)
