Zum Hauptinhalt wechseln
Dyson Cinetic Big Ball Animal Upright Hose Replacement
Was du brauchst
  1. Dyson Cinetic Big Ball Animal Upright Hose Replacement, Hose: Schritt 1, Bild 1 von 2 Dyson Cinetic Big Ball Animal Upright Hose Replacement, Hose: Schritt 1, Bild 2 von 2
    • Lift off the dust bin from the Dyson.
  2. Dyson Cinetic Big Ball Animal Upright Hose Replacement: Schritt 2, Bild 1 von 1
    • Locate the removable hose on the back of the Dyson.
    • Pull up on the hose in order to remove the top half of the hose.
  3. Dyson Cinetic Big Ball Animal Upright Hose Replacement: Schritt 3, Bild 1 von 1
    • Locate the red tab on the frontside of Dyson.
  4. Dyson Cinetic Big Ball Animal Upright Hose Replacement: Schritt 4, Bild 1 von 3 Dyson Cinetic Big Ball Animal Upright Hose Replacement: Schritt 4, Bild 2 von 3 Dyson Cinetic Big Ball Animal Upright Hose Replacement: Schritt 4, Bild 3 von 3
    • Lift up the red tab with the screwdriver while simultaneously pulling on the back hose.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Karla Sunjara
891 Reputation
5 Anleitungen geschrieben
Cal Poly, Team S13-G1, Banghart Winter 2017 Mitglied von Cal Poly, Team S13-G1, Banghart Winter 2017
CPSU-BANGHART-W17S13G1
3 Mitglieder
10 Anleitungen geschrieben
2 Kommentare
Following step 4, I tried to “lift” the red tab with my screwdriver. It did not budge. After enlarging the photo, I saw that the tab can be seen from both sides. Therefore, I tried “pushing” the red tab instead of “lifting” it, and it popped right off. “Lifting” and “pushing” are different actions.
vlkea01 - Antwort
I've taken the small hose out (in the picture, it is in the center at the bottom of the balls) now I cannot get it back in - at one point I thought I had it snapped back in but it didn't stay - any ideas?
K BS - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 15
Letzte 30 Tage: 75
Insgesamt: 11,756
