Einleitung
The hose is located on the backside of the Dyson.
Was du brauchst
Locate the removable hose on the back of the Dyson.
Pull up on the hose in order to remove the top half of the hose.
Lift up the red tab with the screwdriver while simultaneously pulling on the back hose.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
Following step 4, I tried to “lift” the red tab with my screwdriver. It did not budge. After enlarging the photo, I saw that the tab can be seen from both sides. Therefore, I tried “pushing” the red tab instead of “lifting” it, and it popped right off. “Lifting” and “pushing” are different actions.
