Einleitung
The brush bar on the vacuum can wear with use. If your brush is scratching your floor, or not cleaning as well as it used to, then you may want to replace your brush bar.
  1. Turn off the vacuum and unplug it from the outlet.
    • Turn off the vacuum and unplug it from the outlet.
    • Lay the vacuum on its top so that the brush bar faces you.
  2. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  3. Using a quarter,  turn the three soleplate fasteners 90 degrees to the left. Holding the soleplate on both sides, tilt it down and away from the vacuum. Remove the soleplate from the vacuum.
    • Using a quarter, turn the three soleplate fasteners 90 degrees to the left.
    • Holding the soleplate on both sides, tilt it down and away from the vacuum.
    • Remove the soleplate from the vacuum.
  4. Turn down the squared tabs on the brushbar so that they face outward. Use a screwdriver to pry the belt up from the brushbar.
    • Turn down the squared tabs on the brushbar so that they face outward.
    • Use a screwdriver to pry the belt up from the brushbar.
    • Be careful not to cut the belt with the screwdriver.
    • While holding the belt, pull the brushbar to the left and remove it from the vacuum.
    • You can let go of the belt when it's free from the brushbar. The belt will not retract into the vacuum.
    • During reassembly, insert the brushbar with the tabs facing outward, then rotate the tabs up to lock the brushbar in place.
Abschluss
8 weitere Nutzer haben diese Anleitung absolviert.
Donald Percivalle
1.237 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 3-22, Amido Fall 2012 Mitglied von Cal Poly, Team 3-22, Amido Fall 2012
CPSU-AMIDO-F12S3G22
4 Mitglieder
6 Anleitungen geschrieben
Too bad it don't work that easy when reassembling the drive belt over the brush roller. Dyson should reinvent another way and drop dead!
mikemo69 - Antwort
Make sure you get all 4 tabs back in before you close it up. It IS a ##&&% to do on some models.
mjpotter - Antwort
What bout putting the Belt back on? Or does it Put Itself back On The Roller????
Missing Steps!
Herculesx Blade - Antwort
RE-insert brush bar? You mean insert new brush bar? (Not reinsert the old one like in the picture because after all this is instructions for replacing the brush bar right?) Aakkk!
At the bottom it says "to reassemble follow these instructions backwards"...something like that.
Excuse me I have to scream now.
Nichola - Antwort
Thanks, I got you and I know what you meant. Thanks for taking the time to help others.
ronloveflying - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 8
Letzte 7 Tage: 84
Letzte 30 Tage: 491
Insgesamt: 54,285
