Zum Hauptinhalt wechseln
Dyson DC14 Clutch Replacement
Was du brauchst
  1. Dyson DC14 Clutch Replacement, Brush Bar: Schritt 1, Bild 1 von 1
    • Turn off the vacuum and unplug it from the outlet.
    • Lay the vacuum on its top so that the brush bar faces you.
  2. Dyson DC14 Clutch Replacement: Schritt 2, Bild 1 von 3 Dyson DC14 Clutch Replacement: Schritt 2, Bild 2 von 3 Dyson DC14 Clutch Replacement: Schritt 2, Bild 3 von 3
    • Using a quarter, turn the three soleplate fasteners 90 degrees to the left.
    • Holding the soleplate on both sides, tilt it down and away from the vacuum.
    • Remove the soleplate from the vacuum.
  3. Dyson DC14 Clutch Replacement: Schritt 3, Bild 1 von 2 Dyson DC14 Clutch Replacement: Schritt 3, Bild 2 von 2
    • Turn down the squared tabs on the brushbar so that they face outward.
    • Use a screwdriver to pry the belt up from the brushbar.
    • Be careful not to cut the belt with the screwdriver.
    • While holding the belt, pull the brushbar to the left and remove it from the vacuum.
    • You can let go of the belt when it's free from the brushbar. The belt will not retract into the vacuum.
    • During reassembly, insert the brushbar with the tabs facing outward, then rotate the tabs up to lock the brushbar in place.
  4. Dyson DC14 Clutch Replacement, Remove the U-Bend Pipe: Schritt 4, Bild 1 von 2 Dyson DC14 Clutch Replacement, Remove the U-Bend Pipe: Schritt 4, Bild 2 von 2
    • Place vacuum face down.
    • Remove the u-bend pipe that connects the canister to the telescopic wand by pressing the release button and pulling straight out.
  5. Dyson DC14 Clutch Replacement, Remove the Brush Bar Housing: Schritt 5, Bild 1 von 2 Dyson DC14 Clutch Replacement, Remove the Brush Bar Housing: Schritt 5, Bild 2 von 2
    • Pull the clear hose out of the gasket on the right side of the vacuum under the axle.
    • Pull the hose straight back towards you.
    • Note that the rubber cap on the end of the hose has come off in this picture. If this happens, simply pull it off the vacuum and screw it back onto the hose.
  6. Dyson DC14 Clutch Replacement: Schritt 6, Bild 1 von 2 Dyson DC14 Clutch Replacement: Schritt 6, Bild 2 von 2
    • Remove brush-bar housing by prying the housing out of the clips that hold it.
    • Pull brush-bar housing toward you while keeping vacuum stationary.
  7. Dyson DC14 Clutch Replacement, Remove the Clutch Cover: Schritt 7, Bild 1 von 2 Dyson DC14 Clutch Replacement, Remove the Clutch Cover: Schritt 7, Bild 2 von 2
    • Remove the three T15 torx screws that secure the cover to the brush clutch belt.
    • Pull the cover of the brush clutch belt out towards you.
  8. Dyson DC14 Clutch Replacement, Disengage the Drive Belt: Schritt 8, Bild 1 von 1
    • Pull belt to the right to remove the belt from the brush clutch axle.
    • To reassemble your vacuum, pull the belt with your finger towards the axle. (Using a screwdriver, or a similar device, will delay access to the axle.)
  9. Dyson DC14 Clutch Replacement, Remove the Clutch Knob: Schritt 9, Bild 1 von 3 Dyson DC14 Clutch Replacement, Remove the Clutch Knob: Schritt 9, Bild 2 von 3 Dyson DC14 Clutch Replacement, Remove the Clutch Knob: Schritt 9, Bild 3 von 3
    • Two clips secure the clutch knob to the clutch assembly. They can be identified by the half moon cutouts in the interior wall of the clutch knob.
    • Pry the knob off with a flat blade screwdriver.
    • Slide the knob off the clutch.
  10. Dyson DC14 Clutch Replacement, Remove the Clutch: Schritt 10, Bild 1 von 2 Dyson DC14 Clutch Replacement, Remove the Clutch: Schritt 10, Bild 2 von 2
    • Grasp the drive belts and use them as a handle to pull the clutch out of the housing.
  11. Dyson DC14 Clutch Replacement: Schritt 11, Bild 1 von 1
    • The clutch is now free.
Abschluss
5 weitere Nutzer:innen haben diese Anleitung absolviert.
Jerry Wheeler
57.839 Reputation
69 Anleitungen geschrieben
Oregonians Mitglied von Oregonians
Community
7 Mitglieder
176 Anleitungen geschrieben
Ein Kommentar
Clutch belts are tight. There is a commonly available lifter tool to pull the belts far enough to remove and insert the beater bar. I would have been in trouble if I hadn't been able to makeshift a lifter with an L shaped hex wrench and a pair of vice grips to hold onto it.
Andrew Mann - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 16
Letzte 30 Tage: 93
Insgesamt: 1,088
