Zum Hauptinhalt wechseln
Dyson DC24 Dust Bin O-Ring Replacement
Was du brauchst
  1. Dyson DC24 Dust Bin O-Ring Replacement, Dust Bin O-Ring: Schritt 1, Bild 1 von 3 Dyson DC24 Dust Bin O-Ring Replacement, Dust Bin O-Ring: Schritt 1, Bild 2 von 3 Dyson DC24 Dust Bin O-Ring Replacement, Dust Bin O-Ring: Schritt 1, Bild 3 von 3
    • Remove the dirt container by clicking on the red button.
    • Pull away the container from the main body.
  2. Dyson DC24 Dust Bin O-Ring Replacement: Schritt 2, Bild 1 von 2 Dyson DC24 Dust Bin O-Ring Replacement: Schritt 2, Bild 2 von 2
    • Push on the gray release tab on the back of the container.
    • This separates the clear container piece from the filter/suction region.
  3. Dyson DC24 Dust Bin O-Ring Replacement: Schritt 3, Bild 1 von 3 Dyson DC24 Dust Bin O-Ring Replacement: Schritt 3, Bild 2 von 3 Dyson DC24 Dust Bin O-Ring Replacement: Schritt 3, Bild 3 von 3
    • Grab the top filter piece and pull the clear tab out towards you and this should release the top chamber and reveal a filter.
  4. Dyson DC24 Dust Bin O-Ring Replacement: Schritt 4, Bild 1 von 1
    • Remove the filter from the dust container.
    • Depending on the level of cleanliness of the filter you will need to clean it or order a new one.
  5. Dyson DC24 Dust Bin O-Ring Replacement: Schritt 5, Bild 1 von 2 Dyson DC24 Dust Bin O-Ring Replacement: Schritt 5, Bild 2 von 2
    • Use a T15 screwdriver to carefully unscrew and remove five 19.1 mm screws.
    • Make sure to keep the red plastic piece. When putting the pieces back together you will need to orient the red plastic piece properly (see arrow for piece).
  6. Dyson DC24 Dust Bin O-Ring Replacement: Schritt 6, Bild 1 von 3 Dyson DC24 Dust Bin O-Ring Replacement: Schritt 6, Bild 2 von 3 Dyson DC24 Dust Bin O-Ring Replacement: Schritt 6, Bild 3 von 3
    • On the bottom of the piece that lifts up, you will see a hexagonal divider ring. This can be removed by lifting from an edge and pulling.
  7. Dyson DC24 Dust Bin O-Ring Replacement: Schritt 7, Bild 1 von 3 Dyson DC24 Dust Bin O-Ring Replacement: Schritt 7, Bild 2 von 3 Dyson DC24 Dust Bin O-Ring Replacement: Schritt 7, Bild 3 von 3
    • On the bottom piece, there is a second more traditional-looking o-ring. Remove this by grabbing the ring, pulling it out towards you, and down.
Abschluss
With the completion of step 7, you are done. To reassemble your device, follow these instructions in reverse order.
Angel Verdejo
145 Reputation
1 Anleitung geschrieben
UC Davis, Team 1-4, Morris Winter 2023 Mitglied von UC Davis, Team 1-4, Morris Winter 2023
UCD-MORRIS-W23S1G4
2 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 6
Letzte 30 Tage: 18
Insgesamt: 209
