Zum Hauptinhalt wechseln
Dyson DC28 Animal Air Muscle Assembly Replacement
Was du brauchst
  1. Dyson DC28 Animal Air Muscle Assembly Replacement, Sole Plate: Schritt 1, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Coin
    $2.99
    Kaufen
    • Lay the vacuum on its side to allow for easy access to the bottom of the cleaner head.
    • Unlock the sole plate by using a quarter or other flat tool to turn the three plastic bolts counter-clockwise, as indicated on the sole plate.
    • The plastic fasteners can be damaged when using a metal tool to turn them.
  2. Dyson DC28 Animal Air Muscle Assembly Replacement: Schritt 2, Bild 1 von 2 Dyson DC28 Animal Air Muscle Assembly Replacement: Schritt 2, Bild 2 von 2
    • Gently pull off the sole plate
  3. Dyson DC28 Animal Air Muscle Assembly Replacement, Air Muscle Assembly: Schritt 3, Bild 1 von 1
    • Remove the dust collector using the red button located at the top of the bin
  4. Dyson DC28 Animal Air Muscle Assembly Replacement: Schritt 4, Bild 1 von 1
    • Flip the vacuum over to allow for easy access to bottom.
  5. Dyson DC28 Animal Air Muscle Assembly Replacement: Schritt 5, Bild 1 von 3 Dyson DC28 Animal Air Muscle Assembly Replacement: Schritt 5, Bild 2 von 3 Dyson DC28 Animal Air Muscle Assembly Replacement: Schritt 5, Bild 3 von 3
    • Identify the 6 screws.
    • Remove the six 9mm screws using T15 Torx Screwdriver.
  6. Dyson DC28 Animal Air Muscle Assembly Replacement: Schritt 6, Bild 1 von 1
    • Gently remove the drive cover.
  7. Dyson DC28 Animal Air Muscle Assembly Replacement: Schritt 7, Bild 1 von 1
    • Remove the drive assembly.
  8. Dyson DC28 Animal Air Muscle Assembly Replacement: Schritt 8, Bild 1 von 2 Dyson DC28 Animal Air Muscle Assembly Replacement: Schritt 8, Bild 2 von 2
    • Grab the hose by hard plastic base.
    • Pull firmly to remove it from the holder.
    • If you pull too hard the plastic can be ripped.
  9. Dyson DC28 Animal Air Muscle Assembly Replacement: Schritt 9, Bild 1 von 2 Dyson DC28 Animal Air Muscle Assembly Replacement: Schritt 9, Bild 2 von 2
    • Firmly grab top section of the hose and remove from the holder.
  10. Dyson DC28 Animal Air Muscle Assembly Replacement: Schritt 10, Bild 1 von 1
    • Remove section of the hose from the vacuum.
  11. Dyson DC28 Animal Air Muscle Assembly Replacement: Schritt 11, Bild 1 von 2 Dyson DC28 Animal Air Muscle Assembly Replacement: Schritt 11, Bild 2 von 2
    • Go to the wheel on the right side of the vacuum.
    • Remove the cap of wheel by sliding in a small metal spudger or flat head screwdriver and gently prying up.
  12. Dyson DC28 Animal Air Muscle Assembly Replacement: Schritt 12, Bild 1 von 2 Dyson DC28 Animal Air Muscle Assembly Replacement: Schritt 12, Bild 2 von 2
    Metal Spudger
    $2.99
    Kaufen
    • Use the pointed end of a metal spudger to pull off the e-clip.
    • The e-clip is hard to remove and may require some effort to remove.
  13. Dyson DC28 Animal Air Muscle Assembly Replacement: Schritt 13, Bild 1 von 1
    • Pull the wheel off of the axel.
  14. Dyson DC28 Animal Air Muscle Assembly Replacement: Schritt 14, Bild 1 von 1
    • Remove the axel piston from axel.
    • Be careful not to lose the washer on the end of the axel piston.
  15. Dyson DC28 Animal Air Muscle Assembly Replacement: Schritt 15, Bild 1 von 1
    Flush Cutter
    $29.99
    Kaufen
    • Use the wire cutters to cut the zip tie holding the tube on.
    • Be careful not to cut the plastic hose.
  16. Dyson DC28 Animal Air Muscle Assembly Replacement: Schritt 16, Bild 1 von 1
    • Gently pry and pull the tube off of the nub.
  17. Dyson DC28 Animal Air Muscle Assembly Replacement: Schritt 17, Bild 1 von 1
    • Use a flat head screwdriver or metal spudger to push the plastic out of the way and remove the air muscle.
    • Be careful not to break the plastic. Bend it just enough to remove the part.
  18. Dyson DC28 Animal Air Muscle Assembly Replacement: Schritt 18, Bild 1 von 1
    • Remove the air muscle from the rest of the vacuum.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team 21-4, Maness Winter 2017 Mitglied von Cal Poly, Team 21-4, Maness Winter 2017
CPSU-MANESS-W17S21G4
5 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 16
Letzte 30 Tage: 52
Insgesamt: 9,335
