Zum Hauptinhalt wechseln
Dyson DC28 Animal Post/Pre Filter Assemblies Replacement
  1. Dyson DC28 Animal Post/Pre Filter Assemblies Replacement, Post/Pre Filter Assemblies: Schritt 1, Bild 1 von 1
    • Find and press firmly on the red button located above the dust chamber.
    • Hold the handle and pull away from the vacuum base when the button releases the dust chamber.
    • Set off to the side.
  2. Dyson DC28 Animal Post/Pre Filter Assemblies Replacement: Schritt 2, Bild 1 von 2 Dyson DC28 Animal Post/Pre Filter Assemblies Replacement: Schritt 2, Bild 2 von 2
    • Find and firmly press the purple buttons on each side of the pre filter assembly.
    • When the button releases the filter and its casing, lift straight out of vacuum base.
    • After removing the filter in its casing, hold the case with one hand while gently prying the filter out with your other hand.
  3. Dyson DC28 Animal Post/Pre Filter Assemblies Replacement: Schritt 3, Bild 1 von 2 Dyson DC28 Animal Post/Pre Filter Assemblies Replacement: Schritt 3, Bild 2 von 2
    • Find the tab for the post filter cap and pull away from base of vacuum to release the top.
    • When the cap has been swung out of the way, pry the post filter out gently (using same technique as before with pre filter).
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team 21-4, Maness Winter 2017 Mitglied von Cal Poly, Team 21-4, Maness Winter 2017
CPSU-MANESS-W17S21G4
5 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 23
Insgesamt: 1,896
