Einleitung
The cyclone is a method of separating particles from the air within the vacuum. If something goes wrong with the cyclone it could cause issues with suction or even prevent the vacuum from working at all.
Was du brauchst
Push the red lever, pull the back up and away from the dust bin to separate them.
Use a T8-Torque screwdriver to remove the 18mm screw from the back of the Cyclone.
Remove the bottom of the cyclone screen by twisting it to the left and pulling down.
Locate and take out the six 26mm screws with a T-8 Torque screwdriver.
Once you have removed the screws you can remove the rest of the Cyclone.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
