Zum Hauptinhalt wechseln
Dyson DC56 Cyclone Replacement
Was du brauchst
  1. Dyson DC56 Cyclone Replacement, Dust Bin: Schritt 1, Bild 1 von 1
    • Make sure the vacuum is unplugged.
    • Warning: Avoid pressing the red trigger because it will turn on and begin suction.
  2. Dyson DC56 Cyclone Replacement: Schritt 2, Bild 1 von 1
    • Locate the purple button at the top of the device.
  3. Dyson DC56 Cyclone Replacement: Schritt 3, Bild 1 von 1
    • Separate the device with the purple button.
  4. Dyson DC56 Cyclone Replacement: Schritt 4, Bild 1 von 1
    • Locate the dust bin's red release lever on the side of the device.
    • Make sure if the dust bin is full you open the vacuum over a trash can.
  5. Dyson DC56 Cyclone Replacement: Schritt 5, Bild 1 von 1
    • Push the red lever to release the dust bin lid.
  6. Dyson DC56 Cyclone Replacement: Schritt 6, Bild 1 von 1
    • Locate the red lever below the vacuum.
  7. Dyson DC56 Cyclone Replacement: Schritt 7, Bild 1 von 1
    • Push the red lever, pull the back up and away from the dust bin to separate them.
  8. Dyson DC56 Cyclone Replacement, Cyclone: Schritt 8, Bild 1 von 1
    • Use a T8-Torque screwdriver to remove the 18mm screw from the back of the Cyclone.
  9. Dyson DC56 Cyclone Replacement: Schritt 9, Bild 1 von 1
    • Remove the bottom of the cyclone screen by twisting it to the left and pulling down.
  10. Dyson DC56 Cyclone Replacement: Schritt 10, Bild 1 von 1
    • Remove the rest of the cyclone screen by pulling down.
  11. Dyson DC56 Cyclone Replacement: Schritt 11, Bild 1 von 1
    • Locate and take out the six 26mm screws with a T-8 Torque screwdriver.
    • Once you have removed the screws you can remove the rest of the Cyclone.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
USF Tampa, Team S10-G1, Thompson Fall 2017 Mitglied von USF Tampa, Team S10-G1, Thompson Fall 2017
USFT-THOMPSON-F17S10G1
4 Mitglieder
11 Anleitungen geschrieben
Ein Kommentar
I can’t remove the cyclone screen. Any tricks to removing?
J M - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 14
Insgesamt: 953
