Einleitung
The motor is the most important part of the DC56. If the vacuum stops working completely you could need to replace the motor.
Was du brauchst
Locate and remove the 10mm Phillips head screw using a Phillips #1 screw driver.
Locate and remove #000 25mm phillips screw on the reverse side of the vacuum
Pull the battery pack down and away from the main body and remove it from the device.
2 weitere Personen haben diese Anleitung absolviert.
