Zum Hauptinhalt wechseln
Dyson Supersonic HD01 Filter Mesh Replacement
Was du brauchst
  1. Dyson Supersonic HD01 Filter Mesh Replacement, Unlock the filter cover: Schritt 1, Bild 1 von 2 Dyson Supersonic HD01 Filter Mesh Replacement, Unlock the filter cover: Schritt 1, Bild 2 von 2
    • Find the red dot along the top of the filter cover.
    • The red dot will be aligned with the white dot at the bottom of the hair dryer's handle.
    • Twist the filter cover counter-clockwise until the red dot is shifted to align with the white empty circle on the dryer handle.
  2. Dyson Supersonic HD01 Filter Mesh Replacement, Remove the filter cover: Schritt 2, Bild 1 von 2 Dyson Supersonic HD01 Filter Mesh Replacement, Remove the filter cover: Schritt 2, Bild 2 von 2
    • Remove the filter cover by sliding it off of the handle.
  3. Dyson Supersonic HD01 Filter Mesh Replacement, Remove the retaining screws: Schritt 3, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    T6 Torx Screwdriver
    $9.99
    Kaufen
    • Remove the two retaining screws at the base of the handle using a T6 Screwdriver.
  4. Dyson Supersonic HD01 Filter Mesh Replacement, Remove the filter: Schritt 4, Bild 1 von 3 Dyson Supersonic HD01 Filter Mesh Replacement, Remove the filter: Schritt 4, Bild 2 von 3 Dyson Supersonic HD01 Filter Mesh Replacement, Remove the filter: Schritt 4, Bild 3 von 3
    • Seperate the filter mesh at the plastic seam by pulling it apart.
    • Remove the filter mesh by sliding it off of the handle.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Ezra Linza
115 Reputation
1 Anleitung geschrieben
Utah Tech University, Team 1-5, McMurrin Fall 2022 Mitglied von Utah Tech University, Team 1-5, McMurrin Fall 2022
UTAHTECH-MCMURRIN-F22S1G5
3 Mitglieder
3 Anleitungen geschrieben
4 Kommentare
This guide is misleading and obviously trolling. The cable is attached to two ton of power converter bricks there's no way this thing will "slide off" the cable. lol.
gcb - Antwort
The REAL procedure is so complicated, the only REAL tutorial/guide i have found prefers to disassemble the entire device instead of dealing with the power bricks. https://www.youtube.com/watch?v=2XnUlUBZ...
gcb -
slide right off. lol. https://www.youtube.com/watch?v=fsiXJndd... hope you have a saw and several pry tools.
gcb -
updated the guide but i'm not sure how to add steps from another guide (on replacing the motor) up to step 6 only...
gcb - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 6
Letzte 7 Tage: 53
Letzte 30 Tage: 229
Insgesamt: 3,221
