Einleitung
This guide will show you how to replace the motor in your Dyson Supersonic HD01. The motor on your hairdryer may need to be replaced if it has taken damage, and other options to fix your hairdryer have not proven successful.
- Caution: when working with switches and other fragile components, make sure to be gentle and not forceful in removing and inserting parts and electronics.
- Reminder: Upon reassembling, a new adhesive will have to be reapplied for the buttons to be replaced onto the dryer.
Was du brauchst
Find the red dot along the top of the filter cover.
Twist the filter cover counter-clockwise until the red dot is shifted to align with the white empty circle on the dryer handle.
Remove the filter cover by sliding it off of the handle.
In diesem Schritt verwendetes Werkzeug:T6 Torx Screwdriver$9.99
Remove the two retaining screws at the base of the handle using a T6 Screwdriver.
Seperate the filter mesh at the plastic seam by pulling it apart.
Remove the filter mesh by sliding it off of the handle.
Heat the iOpener in the microwave for 30 seconds and apply it immediately to the top of the buttons.
Leave the iOpener in place for a couple minutes.
In diesem Schritt verwendetes Werkzeug:Microfiber Cleaning Cloths$3.99
Remove the buttons with tweezers.
Power button
Cold shot button
Pull down the cover of the hair dryer.
Roll the 2 O-rings down the handle and out of the way.
Pop off the front panel of the hair dryer.
Flip the hair dryer 180 degrees to the back panel.
Remove the three 10 mm screws located on the back of the hair dryer using a T6 Torx screwdriver.
Remove the single T8 screw at the cable end of the back case
Flip the hair dryer back to the front panel.
Remove the four 10 mm screws on the front using a T4 Torx screwdriver.
Remove the back cover of the hair dryer.
Slide down the cover of the motor.
Disconnect the switch on the metal circular area towards the center of the motor.
Disconnect the switch located in the center area of the motor.
Slide off the black sheath on the motor.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
3 Kommentare
Maybe you can help fix the problem? My Dyson Supersonic won't heat up, the company says replace it with 20% discount. But it is only a 3 year old with guarantee expired by 3 months. Is there a chance to fix expensive item? Thanks.
I had a similar experience with a Karcher hand held floor washer. They said: send the silver label via mail and will replace it, but don't send item toss it. This is outrageous that these machines go in the landfill without foreign companies taking charge and try and fix them first. Happened twice, actually. Now Dyson?
