Zum Hauptinhalt wechseln
Dyson V6 Cord-Free Cyclone Replacement
Was du brauchst
  1. Dyson V6 Cord-Free Cyclone Replacement, Cyclone/Motor Unit: Schritt 1, Bild 1 von 3 Dyson V6 Cord-Free Cyclone Replacement, Cyclone/Motor Unit: Schritt 1, Bild 2 von 3 Dyson V6 Cord-Free Cyclone Replacement, Cyclone/Motor Unit: Schritt 1, Bild 3 von 3
    • Make sure the Dyson is unplugged and off before continuing. This is indicated if there is no light on by the charging port.
    • If there is a blue light on the base of the device just below the handle, the device is on. Make sure no light is on.
    • The light can stay on if you unplug the power adapter from the wall but the plug is still connected to the Dyson.
  2. Dyson V6 Cord-Free Cyclone Replacement: Schritt 2, Bild 1 von 3 Dyson V6 Cord-Free Cyclone Replacement: Schritt 2, Bild 2 von 3 Dyson V6 Cord-Free Cyclone Replacement: Schritt 2, Bild 3 von 3
    • Remove any connected attachments on the vacuuming side of the Dyson.
  3. Dyson V6 Cord-Free Cyclone Replacement: Schritt 3, Bild 1 von 3 Dyson V6 Cord-Free Cyclone Replacement: Schritt 3, Bild 2 von 3 Dyson V6 Cord-Free Cyclone Replacement: Schritt 3, Bild 3 von 3
    • Push the red tab against the bin once to open the dust bin.
    • Push the red tab against the bin a second time to release the bin from the cyclone.
  4. Dyson V6 Cord-Free Cyclone Replacement: Schritt 4, Bild 1 von 3 Dyson V6 Cord-Free Cyclone Replacement: Schritt 4, Bild 2 von 3 Dyson V6 Cord-Free Cyclone Replacement: Schritt 4, Bild 3 von 3
    • Take the bin completely off then remove the filter from the cyclone/motor.
    • For reassembly, add a new filter into the top of the new cyclone if one is not included with it.
  5. Dyson V6 Cord-Free Cyclone Replacement: Schritt 5, Bild 1 von 3 Dyson V6 Cord-Free Cyclone Replacement: Schritt 5, Bild 2 von 3 Dyson V6 Cord-Free Cyclone Replacement: Schritt 5, Bild 3 von 3
    • Rest the Dyson upside down on a cushion or something soft.
    • Insert the separator tool between the handle and the cyclone/motor.
    • In the gap you will notice 2 white pins. This is what the separator tool is pushing.
  6. Dyson V6 Cord-Free Cyclone Replacement: Schritt 6, Bild 1 von 3 Dyson V6 Cord-Free Cyclone Replacement: Schritt 6, Bild 2 von 3 Dyson V6 Cord-Free Cyclone Replacement: Schritt 6, Bild 3 von 3
    • With one hand, apply pressure on the tool whilst the other hand holds the cyclone.
    • At the same time, slightly pull the cyclone away from the handle/main component until they are separated.
    • If the separator tool is properly inserted, you will not need to apply excessive force.
  7. Dyson V6 Cord-Free Cyclone Replacement: Schritt 7, Bild 1 von 3 Dyson V6 Cord-Free Cyclone Replacement: Schritt 7, Bild 2 von 3 Dyson V6 Cord-Free Cyclone Replacement: Schritt 7, Bild 3 von 3
    • Move the handle to a firm surface, then with the new cyclone/motor align the top edges of the new cyclone/motor to the interface on the handle.
    • Apply a decent amount of pressure on the new cyclone/motor until you hear it click with the handle.
    • Do not apply excessive pressure or you can crack the cyclone/motor or damage the handle.
Abschluss
Terrell Ottley-Perrotte
180 Reputation
1 Anleitung geschrieben
York University, Team F-26, Woodhouse Fall 2021 Mitglied von York University, Team F-26, Woodhouse Fall 2021
YORK-WOODHOUSE-F21SFG26
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 28
Insgesamt: 697
