Zum Hauptinhalt wechseln
Dyson V6 Cord-Free Cyclone Replacement
Was du brauchst
  1. Dyson V6 Cord-Free Cyclone Replacement, Cyclone/Motor Unit: Schritt 1, Bild 1 von 3 Dyson V6 Cord-Free Cyclone Replacement, Cyclone/Motor Unit: Schritt 1, Bild 2 von 3 Dyson V6 Cord-Free Cyclone Replacement, Cyclone/Motor Unit: Schritt 1, Bild 3 von 3
    • Make sure the Dyson is unplugged and off before continuing. This is indicated if there is no light on by the charging port.
    • If there is a blue light on the base of the device just below the handle, the device is on. Make sure no light is on.
    • The light can stay on if you unplug the power adapter from the wall but the plug is still connected to the Dyson.
    Frag FixBot
    Kommentar hinzufügen
  2. Dyson V6 Cord-Free Cyclone Replacement: Schritt 2, Bild 1 von 3 Dyson V6 Cord-Free Cyclone Replacement: Schritt 2, Bild 2 von 3 Dyson V6 Cord-Free Cyclone Replacement: Schritt 2, Bild 3 von 3
    • Remove any connected attachments on the vacuuming side of the Dyson.
    Frag FixBot
  3. Dyson V6 Cord-Free Cyclone Replacement: Schritt 3, Bild 1 von 3 Dyson V6 Cord-Free Cyclone Replacement: Schritt 3, Bild 2 von 3 Dyson V6 Cord-Free Cyclone Replacement: Schritt 3, Bild 3 von 3
    • Push the red tab against the bin once to open the dust bin.
    • Push the red tab against the bin a second time to release the bin from the cyclone.
    Frag FixBot
  4. Dyson V6 Cord-Free Cyclone Replacement: Schritt 4, Bild 1 von 3 Dyson V6 Cord-Free Cyclone Replacement: Schritt 4, Bild 2 von 3 Dyson V6 Cord-Free Cyclone Replacement: Schritt 4, Bild 3 von 3
    • Take the bin completely off then remove the filter from the cyclone/motor.
    • For reassembly, add a new filter into the top of the new cyclone if one is not included with it.
    Frag FixBot
  5. Dyson V6 Cord-Free Cyclone Replacement: Schritt 5, Bild 1 von 3 Dyson V6 Cord-Free Cyclone Replacement: Schritt 5, Bild 2 von 3 Dyson V6 Cord-Free Cyclone Replacement: Schritt 5, Bild 3 von 3
    • Rest the Dyson upside down on a cushion or something soft.
    • Insert the separator tool between the handle and the cyclone/motor.
    • In the gap you will notice 2 white pins. This is what the separator tool is pushing.
    Frag FixBot
  6. Dyson V6 Cord-Free Cyclone Replacement: Schritt 6, Bild 1 von 3 Dyson V6 Cord-Free Cyclone Replacement: Schritt 6, Bild 2 von 3 Dyson V6 Cord-Free Cyclone Replacement: Schritt 6, Bild 3 von 3
    • With one hand, apply pressure on the tool whilst the other hand holds the cyclone.
    • At the same time, slightly pull the cyclone away from the handle/main component until they are separated.
    • If the separator tool is properly inserted, you will not need to apply excessive force.
    Frag FixBot
  7. Dyson V6 Cord-Free Cyclone Replacement: Schritt 7, Bild 1 von 3 Dyson V6 Cord-Free Cyclone Replacement: Schritt 7, Bild 2 von 3 Dyson V6 Cord-Free Cyclone Replacement: Schritt 7, Bild 3 von 3
    • Move the handle to a firm surface, then with the new cyclone/motor align the top edges of the new cyclone/motor to the interface on the handle.
    • Apply a decent amount of pressure on the new cyclone/motor until you hear it click with the handle.
    • Do not apply excessive pressure or you can crack the cyclone/motor or damage the handle.
    Frag FixBot
Abschluss
Terrell Ottley-Perrotte
180 Reputation
1 Anleitung geschrieben
York University, Team F-26, Woodhouse Fall 2021 Mitglied von York University, Team F-26, Woodhouse Fall 2021
YORK-WOODHOUSE-F21SFG26
1 Mitglied
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 9
Letzte 30 Tage: 44
Insgesamt: 1,322
