Zum Hauptinhalt wechseln
Dyson V6 Motorhead Brush Bar Replacement
Was du brauchst
    1. Dyson V6 Motorhead Brush Bar Replacement, Brush Bar: Schritt 1, Bild 1 von 1
      • Press the button to disconnect the vacuum head from the connecting pole.
      Frag FixBot
      Kommentar hinzufügen
    2. Dyson V6 Motorhead Brush Bar Replacement: Schritt 2, Bild 1 von 1
      • Turn the end cap counterclockwise using the iFixit Opening Tool.
      • If you do not have an iFixit Opening Tool, a quarter may be used instead.
      Frag FixBot
    3. Dyson V6 Motorhead Brush Bar Replacement: Schritt 3, Bild 1 von 3 Dyson V6 Motorhead Brush Bar Replacement: Schritt 3, Bild 2 von 3 Dyson V6 Motorhead Brush Bar Replacement: Schritt 3, Bild 3 von 3
      • Pull the brush bar out of the housing.
      Frag FixBot
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
Cal Poly, Team 22-6, Maness Winter 2017 Mitglied von Cal Poly, Team 22-6, Maness Winter 2017
CPSU-MANESS-W17S22G6
4 Mitglieder
60 Anleitungen geschrieben
4 Kommentare zur Anleitung
Not so fast, there are teeth on the lower roll insert that can interfere with teeth on the housing. Is there a purpose for these teeth, maybe manufacturing mold release? My brush roll will not turn when re-installed. It installs easily, powers up, spins about 4 or 5 revolutions, then shuts off power for a second, then comes back on without the roller spinning at all. I can see it is the teeth interlocking but don’t know how it makes the first 4 or 5 revs. Very strange indeed!!
dooleyew - Antwort Teilen
I have the same problem, where the teeth seem to be engaging and stopping the revolutions. Any fix for this?
Dave Duddleston - Antwort Teilen
I have the same problem and I never signed up for the warranty.
Donna Sweeney - Antwort Teilen
My motorhead works intermittely. I took it apart and cleaned everything to no avail. The guy at Starks vacuum in Sherwood OR said it was plugged and he would take it apart and clean it for $100. Hmmmm, what can he clean that I can’t?
Roger and Karen Risch - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 27
Letzte 30 Tage: 79
Insgesamt: 22,914
