Einleitung
Require battery removal, which is not included due to device not having a battery. Connection tubing will need to be removed before motor replacement.
Was du brauchst
Pull down on the release tab a second time, this time the collection bin should release from the upper vacuum head.
Identify the two white components between the vacuum handle and the attached component.
Insert each arm of the tweezer into each white component area and squeeze simultaneously to release the motor from the attached component.
10 weitere Personen haben diese Anleitung absolviert.
3 Kommentare zur Anleitung
I am terrible at fixing things and this helped me put my vacuum back together after it fell and the motor detached from the handle. Thank you!!!
