Einleitung
Connection tube and brushbar will need to be removed before replacement. Housing for the brushbar may be damaged and break overtime.
Was du brauchst
Press the button to disconnect the vacuum head from the connecting pole.
Turn the padlock key counterclockwise using the iFixit Opening Tool.
Unscrew the top two corner 1.4 cm torx screws using the iFixit T8 Torx screwdriver.
Remove axie and roller after the screws are taken out.
7 weitere Personen haben diese Anleitung absolviert.
6 Kommentare zur Anleitung
Took mine apart and i was certain it was the motor. Removed the drive belt and the motor turned freely. Discovered that the brush pulley was stiff and jammed. Freed it up with wd40 and worked the pulley until it loosened right up. Placed the belt back and now works perfectly. Maybe try this before presuming the motor is burnt out? Just a thought. Cheers!
