Einleitung
The battery pack of the Dyson v6 Absolute provides 20 minutes of powerful, consistent suction on a 3.5-hour charge. It is easily removed and replaced.
Was du brauchst
Push down the red lever located on the outside of the bin, next to the device handle, to open the door to the debris bin.
Avoid pressing the trigger on the handle opposite the red lever, which activates the motor.
Push the red lever down a second time to release the debris bin.
Locate the screw on the battery pack.
Use a Phillips #2 screwdriver to unscrew the battery pack.
Locate the screw on the device handle.
Use a Phillips #2 screwdriver to remove the screw and release the battery pack.
137 weitere Nutzer:innen haben diese Anleitung absolviert.
30 Kommentare
very good article 10 out of 10
Great pictures, very straight forward, and I really appreciate you guys taking the time to put this together. I managed to “kill” my Dyson by getting a little over-zealous with the cleaning. I’m going to take it apart, let it dry completely, and hope that a new battery is the only issue. Anyway, your presentation has given me the courage to go forward - may not work, but…..
Hi, I bought my Dyson v6 for Christmas 2016. My battery only last few seconds at dis stage. It seems a short time for battery needing replacing. Is this normal .
I had the same problem with my dyson v6 slim. The battery didn't last long on mine either! I was very disappointed especially when you pay $500 for one of these.
