Einleitung
If there are issues with the suction of the Dyson v6 Absolute, the cyclone may have to be cleaned or replaced.
Was du brauchst
Push down the red lever located on the outside of the bin, next to the device handle, to open the door to the debris bin.
Avoid pressing the trigger on the handle opposite the red lever, which activates the motor.
Push the red lever down a second time to release the debris bin.
Use tweezers to pinch the white clips together.
Widely hold the tweezers apart to get them to reach between the two white clips.
Because the space is tight between the cyclone and the main body, pinching the white clips may require additional effort.
Tilt and pull the main body away from the cyclone.
There may be a loud snap when the main body separates from the cyclone.
Use the spudger to remove the cyclone.
Start at the small opening beneath the place where the cyclone connects to the main body.
Work the spudger around the rim of the red screen filter.
You will hear popping noises.
Use a T9 Torx screwdriver to remove five 14mm screws from the edge of the screen filter body.
Remove the filter screen cover away from the cyclone.
Pull down on the black tube inside the cyclone body to remove it from the cyclone.
16 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
Very helpful presentation. Reassembly was fiddley as the new cyclone was not broken and needed a very firm waggle and push to engage with the motor body. The white clip is not easy to grasp at the same time as the body and the cyclone.
I found three small broken black plastic pieces under the white clip- from the lugs of the old cyclone - that had to be removed, with tweezers, before assembling the body and cyclone.
