Zum Hauptinhalt wechseln
EDCO Disk Grinder 50200-HD Belt Replacement
Was du brauchst
  1. EDCO Disk Grinder 50200-HD Belt Replacement, Safety precautions: Schritt 1, Bild 1 von 1
    • Before you begin, ensure the device is powered down and cool to the touch.
    • Ensure the machine is unplugged.
    • Turn the power switch counterclockwise into the OFF position.
  2. EDCO Disk Grinder 50200-HD Belt Replacement, Remove the weighted hood: Schritt 2, Bild 1 von 3 EDCO Disk Grinder 50200-HD Belt Replacement, Remove the weighted hood: Schritt 2, Bild 2 von 3 EDCO Disk Grinder 50200-HD Belt Replacement, Remove the weighted hood: Schritt 2, Bild 3 von 3
    • Use a 9/16 inch socket to remove the two bolts securing the weighted hood.
    • During reassembly, ensure the bolts are reinstalled with the washers and lock washers in the correct order.
  3. EDCO Disk Grinder 50200-HD Belt Replacement: Schritt 3, Bild 1 von 3 EDCO Disk Grinder 50200-HD Belt Replacement: Schritt 3, Bild 2 von 3 EDCO Disk Grinder 50200-HD Belt Replacement: Schritt 3, Bild 3 von 3
    • Remove the weighted hood.
    • The weighted hood weighs 37 pounds. Wear gloves and handle with caution.
  4. EDCO Disk Grinder 50200-HD Belt Replacement, Remove the belt: Schritt 4, Bild 1 von 2 EDCO Disk Grinder 50200-HD Belt Replacement, Remove the belt: Schritt 4, Bild 2 von 2
    • Use a 9/16 inch socket to loosen the bolts securing the motor mount.
    • Do not completely remove the bolts.
  5. EDCO Disk Grinder 50200-HD Belt Replacement: Schritt 5, Bild 1 von 2 EDCO Disk Grinder 50200-HD Belt Replacement: Schritt 5, Bild 2 von 2
    • Slide the motor towards the front of the machine as far as it will go to loosen the belt tension.
    • Use a 9/16 inch socket to tighten the four bolts back down to lock the motor in a position where there's the least belt tension.
    • During reassembly, have one person slide the motor mount towards the rear of the machine to tension the belt while the other person tightens the bolts.
  6. EDCO Disk Grinder 50200-HD Belt Replacement: Schritt 6, Bild 1 von 3 EDCO Disk Grinder 50200-HD Belt Replacement: Schritt 6, Bild 2 von 3 EDCO Disk Grinder 50200-HD Belt Replacement: Schritt 6, Bild 3 von 3
    • Tilt the front of the machine up and rest the handlebars on the ground.
    • Have someone hold down the handlebars to prevent tipping while working on the belt.
  7. EDCO Disk Grinder 50200-HD Belt Replacement: Schritt 7, Bild 1 von 3 EDCO Disk Grinder 50200-HD Belt Replacement: Schritt 7, Bild 2 von 3 EDCO Disk Grinder 50200-HD Belt Replacement: Schritt 7, Bild 3 von 3
    • Pinch a flathead screwdriver between the belt and sheave.
    • Rotate the sheave and pivot the belt up and away from its groove.
  8. EDCO Disk Grinder 50200-HD Belt Replacement: Schritt 8, Bild 1 von 2 EDCO Disk Grinder 50200-HD Belt Replacement: Schritt 8, Bild 2 von 2
    • Continue to rotate the sheave with once hand while holding the flathead screwdriver with the other to fully dislodge the belt from the groove.
  9. EDCO Disk Grinder 50200-HD Belt Replacement: Schritt 9, Bild 1 von 3 EDCO Disk Grinder 50200-HD Belt Replacement: Schritt 9, Bild 2 von 3 EDCO Disk Grinder 50200-HD Belt Replacement: Schritt 9, Bild 3 von 3
    • Remove the belt from the motor pulley, then fully remove it from the machine.
    • Reassembly tip: loop the belt around the motor pulley before placing it on the sheave.
  10. EDCO Disk Grinder 50200-HD Belt Replacement, Reassembly tip: Schritt 10, Bild 1 von 3 EDCO Disk Grinder 50200-HD Belt Replacement, Reassembly tip: Schritt 10, Bild 2 von 3 EDCO Disk Grinder 50200-HD Belt Replacement, Reassembly tip: Schritt 10, Bild 3 von 3
    • Reassembly tip: place the belt over the rim and rotate the sheave to guide the belt into the groove.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Sam Omiotek
84.811 Reputation
290 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 9
Insgesamt: 423
