Einleitung
Follow this guide to replace the belt on a EDCO Disk Grinder model 50200-HD.
This repair requires two people.
Was du brauchst
Ensure the machine is unplugged.
Turn the power switch counterclockwise into the OFF position.
Use a 9/16 inch socket to remove the two bolts securing the weighted hood.
Use a 9/16 inch socket to loosen the bolts securing the motor mount.
Slide the motor towards the front of the machine as far as it will go to loosen the belt tension.
Use a 9/16 inch socket to tighten the four bolts back down to lock the motor in a position where there's the least belt tension.
Pinch a flathead screwdriver between the belt and sheave.
Rotate the sheave and pivot the belt up and away from its groove.
Continue to rotate the sheave with once hand while holding the flathead screwdriver with the other to fully dislodge the belt from the groove.
Eine weitere Person hat diese Anleitung absolviert.
