Was du brauchst
Peel back the "ELECTRONIC KITCHEN SCALE" label to reveal two screws underneath.
Remove the top veneer panel. It should come off without any force.
There are two small plastic clips on the edge below the screen, which must be inserted correctly during reassembly.
Remove the screw holding the PCB and screen in place using a #1 Phillips screwdriver.
Remove the PCB and screen assembly.
The buttons should also lift up with the rest of the PCB/screen assembly.
Use a #1 Phillips screwdriver to remove the four screws holding the load cell mount to the base.
Remove the two screws holding the load cell to the bracket using a #2 Phillips screwdriver.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
