Einleitung
The power supply works as the package is designed and built but I found the adjustable voltage potentiometers to be very touchy as to getting to an exact voltage desired and a bump of the knob would through that off. While not a major problem, I found it frustrating when wanting the positive and negative voltages to match for a project.
New Potentiometers: https://www.amazon.com/dp/B07MQ7R5C7/?co...
Was du brauchst
UNPLUG Power Supply from any external power and disconnect all cables.
Remove the two #1 philips head screws from the sides of the power supply.
Take a photograph of your wiring before starting to make sure you get them back correct.
Using your desoldering equipment desolder the 4 leads going to the two voltage control potentiometers.
Remove the 2 potentiometers and all their hardware.
To fix this it was a simple fix of replacing the 2K Ohm standard potentiometers for voltage adjustment with a 10 turn precision potentiometer.
Insert the new potentiometers in their places.
Solder all four wires back to each post.
Put new 10 turn knobs on the front.
Plug power supply in and test functioning.
Put cover back on with four #1 philips screws.
You are done.
You are replacing VR1 & VR2 which are the 2 K voltage adjustment potentiometers for the variable power supplies. See page 18 of the pdf
Link to part on Amazon. https://www.amazon.com/dp/B07MQ7R5C7/?co...
Eine weitere Person hat diese Anleitung absolviert.
