Einleitung
The buttons on these speakers can fail. If it is the main power button, it will prevent the speaker switching on completely.
Was du brauchst
The buttons on these speakers can fail due to corrosion or repeated pressing. They are easy to replace.
Peel off the silicone cover. It is glued on with double-sided tape which can be removed with isopropanol if desired.
You can cut out the old switch using flush cutters or a rotary tool, be careful not to rip the solder pads of the circuit board.
Alternatively, use a hot air gun. You can use low-melting solder to make removal easier.
Solder the replacement button into place using a hot air gun, solder and flux.
The buttons measure 5.1mm x 5.1mm (excluding the legs). They are about 1.5mm tall excluding the push button
Reassembly is very simple, you can stick the silicone in case and push the cap back on.
