Einleitung
The fan is a vital portion of the EVGA Supernova Nex 650 G Power Supply. This guide will show you how to dissassemble the power supply and fix it.
Was du brauchst
Disconnect all wires attached to the power supply before performing any actions on the power supply.
If the power supply was recently plugged into the wall, allow 10 minutes for the internal capacitors to discharge. '
Using the 2mm Hex Key, remove the four screws located on the four corners on the bottom (fan side) of the power supply.
Using the 2.5 mm Hex Key, remove the four screws holding the fan and its vent on the power supply.
Use a flat head screwdriver under the tab to remove the top from the bottom.
Once the top has been removed, move the fan out of the way to expose the wiring and circuit board.
Cut the zip ties that wrap all the wire together to remove the fan wire. There are 3 zip ties to be removed. Use a xacto knife or scissors.
Cut the gray welding caulk material so that you can remove the fan from the motherboard
Follow the wire to find where the fan connects to the board.
Using the needle nose pliers grab onto the plastic end of the wire and pull very lightly up on the plastic. Simultaneously, use the corner of the screwdriver to apply light pressure to the two holes to release the from being connected to the board. Doing this should allow for the the fan to be released from the board.
Remove the defective fan from the power supply.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
Hey, I appreciate the guide! Is the owner who created this guide still around? If so please comment back. I have a few questions in regards to this power supply that I think you could answer.
Thank you!
