Zum Hauptinhalt wechseln
EasySMX ESM-9110 Backplate Replacement
Was du brauchst
  1. EasySMX ESM-9110 Backplate Replacement, Handle Covers: Schritt 1, Bild 1 von 2 EasySMX ESM-9110 Backplate Replacement, Handle Covers: Schritt 1, Bild 2 von 2
    • Use a Phillips #000 screwdriver to remove the two 10 mm screws from the back of controller.
    Frag FixBot
    Kommentar hinzufügen
  2. EasySMX ESM-9110 Backplate Replacement: Schritt 2, Bild 1 von 1
    • Insert a plastic opening tool into the slit on the side of controller.
    • Wiggle the tool until the cover becomes loose.
    • Repeat this on the other side of Controller.
    • Go slow. Take your time removing the handle covers.
    Frag FixBot
  3. EasySMX ESM-9110 Backplate Replacement: Schritt 3, Bild 1 von 1
    • Remove the faceplate.
    • Repeat on the other side of the controller.
    Frag FixBot
  4. EasySMX ESM-9110 Backplate Replacement, Backplate: Schritt 4, Bild 1 von 3 EasySMX ESM-9110 Backplate Replacement, Backplate: Schritt 4, Bild 2 von 3 EasySMX ESM-9110 Backplate Replacement, Backplate: Schritt 4, Bild 3 von 3
    • Use a Phillips #000 screwdriver to remove four 20 mm screws from the controller's faceplate.
    • Use a Phillips #000 screwdriver (a screwdriver bit extension may be needed) to remove the two 20 mm screws from the controllers faceplate.
    • Screw extender should only be used to unscrew two of the six screws. Do not use for all six.
    Frag FixBot
  5. EasySMX ESM-9110 Backplate Replacement: Schritt 5, Bild 1 von 1
    • Remove the faceplate of the controller by lifting it directly up from the backplate.
    • Be gentle. The controllers backplate is still attached to the faceplate.
    Frag FixBot
  6. EasySMX ESM-9110 Backplate Replacement: Schritt 6, Bild 1 von 3 EasySMX ESM-9110 Backplate Replacement: Schritt 6, Bild 2 von 3 EasySMX ESM-9110 Backplate Replacement: Schritt 6, Bild 3 von 3
    • Use a Phillips #000 screwdriver to remove the two 10 mm screws from the daughterboard off the backplate.
    • Remove the daughterboard once screws are off.
    • Be gentle when removing the daughterboard. The daughterboard is still attached to the faceplate.
    Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
UMass Dartmouth, Team 2-4, Konn Spring 2024 Mitglied von UMass Dartmouth, Team 2-4, Konn Spring 2024
UMASSD-KONN-S24S2G4
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 7
Letzte 30 Tage: 53
Insgesamt: 585
