Zum Hauptinhalt wechseln
EasySMX ESM-9110 Joystick Cover Replacement
Was du brauchst
  1. EasySMX ESM-9110 Joystick Cover Replacement, Backplate: Schritt 1, Bild 1 von 3 EasySMX ESM-9110 Joystick Cover Replacement, Backplate: Schritt 1, Bild 2 von 3 EasySMX ESM-9110 Joystick Cover Replacement, Backplate: Schritt 1, Bild 3 von 3
    • Use a Phillips #000 screwdriver to remove four 20 mm screws from the controller's faceplate.
    • Use a Phillips #000 screwdriver (a screwdriver bit extension may be needed) to remove the two 20 mm screws from the controllers faceplate.
    • Screw extender should only be used to unscrew two of the six screws. Do not use for all six.
    Frag FixBot
  2. EasySMX ESM-9110 Joystick Cover Replacement: Schritt 2, Bild 1 von 1
    • Remove the faceplate of the controller by lifting it directly up from the backplate.
    • Be gentle. The controllers backplate is still attached to the faceplate.
    Frag FixBot
  3. EasySMX ESM-9110 Joystick Cover Replacement: Schritt 3, Bild 1 von 3 EasySMX ESM-9110 Joystick Cover Replacement: Schritt 3, Bild 2 von 3 EasySMX ESM-9110 Joystick Cover Replacement: Schritt 3, Bild 3 von 3
    • Use a Phillips #000 screwdriver to remove the two 10 mm screws from the daughterboard off the backplate.
    • Remove the daughterboard once screws are off.
    • Be gentle when removing the daughterboard. The daughterboard is still attached to the faceplate.
    Frag FixBot
  4. EasySMX ESM-9110 Joystick Cover Replacement, Joystick Cover: Schritt 4, Bild 1 von 2 EasySMX ESM-9110 Joystick Cover Replacement, Joystick Cover: Schritt 4, Bild 2 von 2
    • Remove the four 10 mm Phillips screws from the motherboard.
    • Be careful removing the motherboard as the trigger buttons are attached loosely and can be inconvenient.
    Frag FixBot
  5. EasySMX ESM-9110 Joystick Cover Replacement: Schritt 5, Bild 1 von 1
    • Remove the faulty joystick.
    • Clean the joystick if it is dirty and causing stick drift.
    Frag FixBot
Abschluss
Caleb French
91 Reputation
1 Anleitung geschrieben
UMass Dartmouth, Team 2-4, Konn Spring 2024 Mitglied von UMass Dartmouth, Team 2-4, Konn Spring 2024
UMASSD-KONN-S24S2G4
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 49
Insgesamt: 1,012
