Einleitung
This guide is a detailed process on how to remove the vibration motors on the EasySMX ESM-9110 gaming controller. The EasySMX ESM-9110 controller contains two vibration motors which operate during gameplay. The replacement of these vibration motors will most likely fix any issues being had.
Was du brauchst
Use a Phillips #000 screwdriver to remove the two 10 mm screws from the back of controller.
Insert a plastic opening tool into the slit on the side of controller.
Wiggle the tool until the cover becomes loose.
Repeat this on the other side of Controller.
Use a Phillips #000 screwdriver to remove the four 20 mm screws from the controller's faceplate.
Use a Phillips #000 screwdriver (a screwdriver bit extension may be needed) to remove the two 20 mm screws from the controllers faceplate.
Remove the faceplate of the controller by lifting it directly up from the backplate.
Locate the parts of the vibration motor that are connected to the motherboard
Solder these parts of the vibration motor to remove them.
