Zum Hauptinhalt wechseln
EasySMX X15 Battery Replacement
Was du brauchst
  1. EasySMX X15 Battery Replacement, Bottom Casing: Schritt 1, Bild 1 von 2 EasySMX X15 Battery Replacement, Bottom Casing: Schritt 1, Bild 2 von 2
    • Use a Phillips #00 screwdriver to remove the four 9 mm screws from the bottom of the EasySMX X15.
    • Use an opening tool to gently pry between the seams of the controller to separate the lower and upper casings.
    • Be gentle when separating the lower casing from the upper casing to avoid breaking any of the plastic snap tabs.
    Frag FixBot
    Kommentar hinzufügen
  2. EasySMX X15 Battery Replacement, Battery: Schritt 2, Bild 1 von 3 EasySMX X15 Battery Replacement, Battery: Schritt 2, Bild 2 von 3 EasySMX X15 Battery Replacement, Battery: Schritt 2, Bild 3 von 3
    • Push on alternating sides of the connector to disconnect the red battery cable from the board.
    • If that doesn't work, use a pair of tweezers to firmly grip the sides of the connector and pull straight away from the socket. Hold the tweezers closer to the connector to get a better grip.
    • Pull from the tab, not the cables, to avoid damaging them.
    Frag FixBot
  3. EasySMX X15 Battery Replacement: Schritt 3, Bild 1 von 1
    • Use a spudger to pry the battery loose from the controller.
    • The battery is glued onto the control board, so it may take a bit of work to release it from the adhesive.
    • Remove the battery.
    • Don't bend or pierce the battery. If the battery is swollen, follow the guidelines outlined in this article.
    Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Austin Community College, Team 7-3, Watkins Fall 2024 Mitglied von Austin Community College, Team 7-3, Watkins Fall 2024
AUSTINCC-WATKINS-F24S7G3
3 Mitglieder
7 Anleitungen geschrieben
1 Kommentar zur Anleitung
What battery do i need compatible with this controller? where i can find it?
Manel Leiva - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 10
Letzte 30 Tage: 57
Insgesamt: 982
