Zum Hauptinhalt wechseln
EasySMX X15 D-Pad Replacement
Was du brauchst
  1. EasySMX X15 D-Pad Replacement, Bottom Casing: Schritt 1, Bild 1 von 2 EasySMX X15 D-Pad Replacement, Bottom Casing: Schritt 1, Bild 2 von 2
    • Use a Phillips #00 screwdriver to remove the four 9 mm screws from the bottom of the EasySMX X15.
    • Use an opening tool to gently pry between the seams of the controller to separate the lower and upper casings.
    • Be gentle when separating the lower casing from the upper casing to avoid breaking any of the plastic snap tabs.
    Frag FixBot
    Kommentar hinzufügen
  2. EasySMX X15 D-Pad Replacement, Main Board: Schritt 2, Bild 1 von 1
    • Disconnect the vibration motor cables from the connectors on the circuit board.
    • Use a Phillips #00 screwdriver to remove six, 6mm screws from the board.
    Frag FixBot
  3. EasySMX X15 D-Pad Replacement: Schritt 3, Bild 1 von 1
    • Gently lift the board away from the upper casing, maneuvering it around the triggers by lifting it from the bottom, away from the upper casing.
    Frag FixBot
  4. EasySMX X15 D-Pad Replacement, D-Pad: Schritt 4, Bild 1 von 2 EasySMX X15 D-Pad Replacement, D-Pad: Schritt 4, Bild 2 von 2
    • Use the Phillips #00 screwdriver to remove the four 4 mm screws securing the D-pad to the controller casing.
    • Lift the back of the D-pad, along with the membrane, to remove them from the controller.
    • Lift up the case, allowing the D-pad to detach from the top of the casing.
    Frag FixBot
Abschluss
Austin Community College, Team 7-3, Watkins Fall 2024 Mitglied von Austin Community College, Team 7-3, Watkins Fall 2024
AUSTINCC-WATKINS-F24S7G3
3 Mitglieder
7 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 9
Letzte 30 Tage: 57
Insgesamt: 547
