Zum Hauptinhalt wechseln
EasySMX X15 Vibration Motor Replacement
Was du brauchst
  1. EasySMX X15 Vibration Motor Replacement, Bottom Casing: Schritt 1, Bild 1 von 2 EasySMX X15 Vibration Motor Replacement, Bottom Casing: Schritt 1, Bild 2 von 2
    • Use a Phillips #00 screwdriver to remove the four 9 mm screws from the bottom of the EasySMX X15.
    • Use an opening tool to gently pry between the seams of the controller to separate the lower and upper casings.
    • Be gentle when separating the lower casing from the upper casing to avoid breaking any of the plastic snap tabs.
    Frag FixBot
    Kommentar hinzufügen
  2. EasySMX X15 Vibration Motor Replacement, Battery: Schritt 2, Bild 1 von 3 EasySMX X15 Vibration Motor Replacement, Battery: Schritt 2, Bild 2 von 3 EasySMX X15 Vibration Motor Replacement, Battery: Schritt 2, Bild 3 von 3
    • Push on alternating sides of the connector to disconnect the red battery cable from the board.
    • If that doesn't work, use a pair of tweezers to firmly grip the sides of the connector and pull straight away from the socket. Hold the tweezers closer to the connector to get a better grip.
    • Pull from the tab, not the cables, to avoid damaging them.
    Frag FixBot
  3. EasySMX X15 Vibration Motor Replacement: Schritt 3, Bild 1 von 1
    • Use a spudger to pry the battery loose from the controller.
    • The battery is glued onto the control board, so it may take a bit of work to release it from the adhesive.
    • Remove the battery.
    • Don't bend or pierce the battery. If the battery is swollen, follow the guidelines outlined in this article.
    Frag FixBot
  4. EasySMX X15 Vibration Motor Replacement, Vibration Motor: Schritt 4, Bild 1 von 1
    Frag FixBot
  5. EasySMX X15 Vibration Motor Replacement: Schritt 5, Bild 1 von 1
    • Slide the motor out of the housing.
    Frag FixBot
Abschluss
Austin Community College, Team 7-3, Watkins Fall 2024 Mitglied von Austin Community College, Team 7-3, Watkins Fall 2024
AUSTINCC-WATKINS-F24S7G3
3 Mitglieder
7 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 15
Letzte 30 Tage: 34
Insgesamt: 321
