Einleitung
If your monitor and display is working, but your camera wont turn on then here is a guide on how to replace it. The only tools you will need is a #1 Philips head screwdriver and a #00 Phillips head screwdriver if needed.
Was du brauchst
Unscrew the two silver 1.4 mm Phillips #1 screws connecting the metal bar to the camera.
Take the two tabs off the sides of the camera by unscrewing the four 1.2 mm Phillips #1 screws connected.
When the screws are out, pop the two tabs off the sides.
Then you can pull off the back panel. You will then be left with the camera and wires. To install the new camera simply retrace these steps.
