Zum Hauptinhalt wechseln
EchoMaster MRC-WLP43 Motherboard Replacement
Was du brauchst
  1. EchoMaster MRC-WLP43 Motherboard Replacement, Motherboard: Schritt 1, Bild 1 von 1
    • Take your monitor and face in down so that the back is facing up. There will be four screws on each corner of the monitors back cover. Unscrew each one and set them to the side. Remove four 1.2 mm Phillips #1 screws.
    • Don't lose your screws!
  2. EchoMaster MRC-WLP43 Motherboard Replacement: Schritt 2, Bild 1 von 2 EchoMaster MRC-WLP43 Motherboard Replacement: Schritt 2, Bild 2 von 2
    • Carefully lift the back along with the screen then flip it around slowly so the back is placed down on the table.
    • The back is connected to the motherboard and screen so lift with caution!
    • Lift your screen above the motherboard and set it down.
  3. EchoMaster MRC-WLP43 Motherboard Replacement: Schritt 3, Bild 1 von 1
    • There are three screws on the motherboard. Unscrew each one of the three 1.4 mm Phillips #1 screws.
  4. EchoMaster MRC-WLP43 Motherboard Replacement: Schritt 4, Bild 1 von 2 EchoMaster MRC-WLP43 Motherboard Replacement: Schritt 4, Bild 2 von 2
    • Once the screws are out, you can then remove the yellow strip connecting the screen to the motherboard.
    • There is a black tab that you can carefully flip up with your fingernail or a flathead screwdriver. Once it's flipped up you can easily slide the yellow ribbon out.
  5. EchoMaster MRC-WLP43 Motherboard Replacement: Schritt 5, Bild 1 von 1
    • When everything is unscrewed and removed you can take your motherboard out of the back cover and replace it by retracing these steps.
Abschluss
Cheska king
691 Reputation
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 12
Letzte 30 Tage: 17
Insgesamt: 92
