Zum Hauptinhalt wechseln
Eclipse 180BL Battery Replacement
Was du brauchst
  1. Eclipse 180BL Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Remove the two screws located on the bottom of the device with a phillips head screw driver.
    • The two screws can be removed using the PH00 head from the iFixit repair toolkit.
    • Both screws are 1/8 inch in length.
    • The bottom cap will come off to reveal the inside main component.
  2. Eclipse 180BL Battery Replacement: Schritt 2, Bild 1 von 2 Eclipse 180BL Battery Replacement: Schritt 2, Bild 2 von 2
    • Remove the main inner component using Spudger, by pushing on the USB port. This will take some force.
    • Hold on the sides with your fingers, and push to release from the top.
  3. Eclipse 180BL Battery Replacement: Schritt 3, Bild 1 von 3 Eclipse 180BL Battery Replacement: Schritt 3, Bild 2 von 3 Eclipse 180BL Battery Replacement: Schritt 3, Bild 3 von 3
    • The plastic LCD cover and the key pad will now be loose; they were held in place by the tension between the case and the internal main component.
    • Locate the large square pack with a black and red wire coming out of it, this is the battery.
    • Cut the red and black wires to remove the old battery.
  4. Eclipse 180BL Battery Replacement: Schritt 4, Bild 1 von 1
    • To Replace, connect the two new lines ( red and black) between the new battery and the device.
    • You have successfully replaced the battery!
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
USF Sarasota-Manatee, Team 1-2, Stewart Fall 2015 Mitglied von USF Sarasota-Manatee, Team 1-2, Stewart Fall 2015
USFSM-STEWART-F15S1G2
5 Mitglieder
17 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 25
Insgesamt: 1,357
