Einleitung
Following these easy steps will allow you to successfully replace the battery in the device.
Was du brauchst
Remove the two screws located on the bottom of the device with a phillips head screw driver.
The bottom cap will come off to reveal the inside main component.
Remove the main inner component using Spudger, by pushing on the USB port. This will take some force.
Hold on the sides with your fingers, and push to release from the top.
To Replace, connect the two new lines ( red and black) between the new battery and the device.
You have successfully replaced the battery!
3 weitere Personen haben diese Anleitung absolviert.
