Zum Hauptinhalt wechseln
Eclipse 180BL Touch Pad Replacement
Was du brauchst
  1. Eclipse 180BL Touch Pad  Replacement, Touch Pad: Schritt 1, Bild 1 von 1
    • Remove the two screws at the bottom of the device.
    • The two screws can be removed using the PH00 head located in the iFixit Repair toolkit.
    • The two screws are 1/8 inch in length.
    • Remove the cover to reveal the internal component.
  2. Eclipse 180BL Touch Pad  Replacement: Schritt 2, Bild 1 von 3 Eclipse 180BL Touch Pad  Replacement: Schritt 2, Bild 2 von 3 Eclipse 180BL Touch Pad  Replacement: Schritt 2, Bild 3 von 3
    • Using the Spudger, forcefully push upward on the USB port of the device to remove the main component.
    • This will release the tension on the multiple parts. One of which will be the touch pad.
    • The touch pad can now be easily replaced.
    • The touch pad has a smaller center piece that must be replaced for proper usage of the device.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 14
Insgesamt: 841
