Einleitung
This guide is required when the device fails to power on and it has been determined that it is due to an issue with the battery. In order to replace the battery, soldering is required which is a safety hazard and requires specific equipment. When soldering, protective equipment should be worn and extreme caution should be taken.
Was du brauchst
Using the screwdriver with the J00 bit, remove the two 4.8 mm Phillips screws.
Using the small metal pry bar, remove the bottom plastic cover.
Using your thumb, press down on the home button and hold the metal casing. With your other hand hold the top plastic part of the device. At the same time slide the metal casing and the plastic casing apart.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
