Zum Hauptinhalt wechseln
Eclipse MTE28VGM Lens Cover Replacement
Was du brauchst
  1. Eclipse MTE28VGM Lens Cover Replacement, Lens Cover: Schritt 1, Bild 1 von 3 Eclipse MTE28VGM Lens Cover Replacement, Lens Cover: Schritt 1, Bild 2 von 3 Eclipse MTE28VGM Lens Cover Replacement, Lens Cover: Schritt 1, Bild 3 von 3
    • Using the screwdriver with the J00 bit, remove the two 4.8 mm Phillips screws.
    • Use caution when removing the screws as they can strip easily.
  2. Eclipse MTE28VGM Lens Cover Replacement: Schritt 2, Bild 1 von 3 Eclipse MTE28VGM Lens Cover Replacement: Schritt 2, Bild 2 von 3 Eclipse MTE28VGM Lens Cover Replacement: Schritt 2, Bild 3 von 3
    • Using the small metal pry bar, remove the bottom plastic cover.
    • Using your thumb, press down on the home button and hold the metal casing. With your other hand hold the top plastic part of the device. At the same time slide the metal casing and the plastic casing apart.
    • On occasion the battery can become swollen and make this process difficult. You might need to use the spudger to push on the bottom components to assist in the separation.
  3. Eclipse MTE28VGM Lens Cover Replacement: Schritt 3, Bild 1 von 2 Eclipse MTE28VGM Lens Cover Replacement: Schritt 3, Bild 2 von 2
    • Using the plastic spudger, pry the plastic lens cover off of the camera.
    • Attach the replacement plastic lens cover to the camera.
Abschluss
Tyler Hudgens
288 Reputation
2 Anleitungen geschrieben
IUPUI, Team 2-1, Harley Fall 2016 Mitglied von IUPUI, Team 2-1, Harley Fall 2016
IUPUI-HARLEY-F16S2G1
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 9
Insgesamt: 196
