Einleitung
Replacing the case is relatively simplistic and requires only the use of a screwdriver, plastic remover tools, and takes about 1 hour to complete.
Was du brauchst
Using the screwdriver with the J00 bit, remove the two 4.8 mm Phillips screws.
Using the small metal pry bar, remove the bottom plastic cover.
Using your thumb, press down on the home button and hold the metal casing. With your other hand hold the top plastic part of the device. At the same time slide the metal casing and the plastic casing apart.
Using the screwdriver, remove the four 4.8 mm Phillips head J00 screws at each corner of the motherboard.
Remove the motherboard from the front plastic cover and screen.
Install new plastic case following steps in reverse order
