Zum Hauptinhalt wechseln
Eco X Gear Battery Replacement
Was du brauchst
  1. Eco X Gear Battery Replacement, Frame: Schritt 1, Bild 1 von 1
    • Disconnect any power source and/or turn off device.
  2. Eco X Gear Battery Replacement: Schritt 2, Bild 1 von 1
    • Remove the 15 rubber plugs from the cavities using needle nose pliers.
  3. Eco X Gear Battery Replacement: Schritt 3, Bild 1 von 1
    • Use a phillips head screwdriver to remove the fifteen 6.4mm screws.
  4. Eco X Gear Battery Replacement: Schritt 4, Bild 1 von 1
    • Carefully separate the two sections of the frame.
    • Wires still connect the two sections. Be cautious to avoid damaging the wires, terminals, and electronics.
  5. Eco X Gear Battery Replacement, Battery: Schritt 5, Bild 1 von 1
    • Disconnect the wiring to improve accessibility to the battery.
  6. Eco X Gear Battery Replacement: Schritt 6, Bild 1 von 2 Eco X Gear Battery Replacement: Schritt 6, Bild 2 von 2
    • Remove the two screws that hold that bracket, securing the battery in place.
  7. Eco X Gear Battery Replacement: Schritt 7, Bild 1 von 1
    • Disconnect the wires that hold the batteries down to the motherboard.
  8. Eco X Gear Battery Replacement: Schritt 8, Bild 1 von 1
    • Pry the battery from the frame using your hands or an opening pick.
  9. Eco X Gear Battery Replacement: Schritt 9, Bild 1 von 1
    • When removing and installing the battery, be cautious to not damage any of the surrounding electronics.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
James Lipsett
625 Reputation
6 Anleitungen geschrieben
UMass Dartmouth, Team S9-G3, Martin Spring 2017 Mitglied von UMass Dartmouth, Team S9-G3, Martin Spring 2017
UMASSD-MARTIN-S17S9G3
2 Mitglieder
3 Kommentare
Where to get the new battery?
James Chen - Antwort
Hello EcoXGear lovers, i just bought this battery from amazon yesterday and perfect fit with polarity you can get the battery here
https://www.amazon.com/gp/product/B08ZCQ...
partha - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 6
Letzte 30 Tage: 26
Insgesamt: 675
