Einleitung
You will need a phillips head screw driver and needle nose pliers to complete this task. Before opening the device, ensure that there is no power to avoid damaging the electronics or harming yourself.
Was du brauchst
Remove the four screws which hold down the speaker. Then, pry up the speaker from the frame.
To replace the cone, remove the existing one by peeling it off of the speaker with needle nose pliers.
Fast fertig!
Abschluss
