Einleitung
You will need a phillips head screw driver and needle nose pliers to complete this task. Before opening the device, ensure that there is no power to avoid damaging the electronics or harming yourself.
Was du brauchst
Inspect the gasket around the perimeter of the frame. Remove the gasket using your fingers or needle nose pliers.
Fast fertig!
Abschluss
